water pump for an A?
Brad
09-12-2003 11:16:05
My 1946 A has a thermosiphon cooling system; however, I have seen aftermarket water pumps for the A series listed on eBay and in catalogues. Is there any advantage to retrofitting an A with a water pump or do they do just fine as they are? Mine was built as a distillate tractor and has the original all-fuel manifold, pistons, and radiator shutter.
gene b
09-13-2003 03:22:48
 Re: water pump for an A? in reply to Brad, 09-12-2003 11:16:05
Just get one for a C get a longer belt and go for it they work great many are done this way on both the A and B. Thes tractors are getting old and build-up in the blocks can plug the natural flow of the system. Have replaced several sleeves and pistons the last few years in retirement and after the sleeve is removed it is something to see all the junk at the bottom of the sleeve in the block plugging the holes that alow the flow of water by the bottom of the sleeve. You can also remove the radiator and lower housing and with high pressure water and air and some stiff wire remove a lot of this residue. The water pump is a wonderful idea if you are using the tractor a lot in hot weather.
Ron/PA
09-12-2003 12:04:41
I've never ever over heated my Super A, as long as everything was working properly. Mine is pre-water pump as well. I always figure if it ain't broke don't fix it! Later
Ron
