H front wheel bolts
bill
09-24-2003 16:51:45
I am breaking down the fron end assembly on my 40 model H.
The front wheel bolts are pretty rusty.
Q: Can I just replace them with a grade 8 bolt of the same size, or do I need to order them from the IH dealer?
Shouldn't they be "coated" with something?
bill
CNKS
09-24-2003 18:43:09
 Re: H front wheel bolts in reply to bill, 09-24-2003 16:51:45
A related question was asked a few days ago. They don't list the grade, but look at Link
CNKS
09-24-2003 18:45:12
 Re: Re: H front wheel bolts in reply to CNKS, 09-24-2003 18:43:09
Too lazy to repost -- that's /catalog12.html. Note the . between the 2 and h.
Andy Martin
09-24-2003 17:06:26
Even grade 5 bolts will work fine. Fine thread bolts hold the vibration a little better.
Most bolts are cadmium plated which helps avoid rust.
I don't think you can get original style bolts from IH even if you are a real purist.
Dave_Id
09-24-2003 17:06:10
I'm assuming you are talking about those square bolts holding the clamps on the rims, right? I'd be surprised if they even classified those as Class 2. Other hex bolts will certainly work, but they'll spin in the cast wheel, cuz they have a smaller area gripping the metal, than the square head. NiCad bolts of course won't rust as easy, the square ones don't have any coating, but can be painted, or lubed with NeverSeize on assembly
Haas
09-24-2003 18:18:11
 Re: Re: H front wheel bolts in reply to Dave_Id, 09-24-2003 17:06:10
Grade 2 bolts are not adequate for the wheel clamps, either on the front or the rear. The original IH bolts are definitely more than a grade 2. I think a grade 5 would be adequate, the grade 8 better. It's hard to find square head bolts in grade 5 or better. Most of the after market folks I've found selling square head bolts have grade 2 bolts. I've passed them up and gone to the IH dealer or used hex head bolts. Hex heads work pretty good on the front wheels, but I would avoid them on the rear.
bill
09-24-2003 17:50:58
does anyone make square head bolts anymore?
Paul in Mich
09-24-2003 18:18:57
 Re: Re: Re: H front wheel bolts in reply to bill, 09-24-2003 17:50:58
Bill, You can find square head bolts at most any fastener supply house. I don't know how big your town is, but most cities of 30,000 or more population will most likely have a wholesale supplier. Grade 8 is an over-kill for sure. Grade 5 or even grade 3 will do just fine. Fine thread is best, and use flat washers and lock washers, and hex nuts. coating the threads with never-seize will keep the bolts from rusting, provided you dont get bolts too long. 1/8th inch of threads showing after tightening is plenty.
