Radiatorcap 1940 H
Brad L
10-03-2003 14:04:52
I am wondering is he radiator cap on a 1940 H is a pressure cap or is it just to keep the coolant from leaking. I have the big red cap that was original to them. I was looking at pictures and all I see is regular caps. If they are pressure caps what is the pounds they are supposed to hold?One more ? Where would you get a crank for one of these?
Brad L
10-05-2003 08:28:04
 Re: Radiatorcap 1940 H in reply to Brad L, 10-03-2003 14:04:52
Thanks-I couldn't see how that cap would hold pressure Brad
CNKS
10-03-2003 19:22:42
Your system is non-pressurized. The H began using a pressure radiator cap at Serial # 115030 (late 1942).
rustyfarmall
10-03-2003 14:26:44
If the radiator is the original, then it is a nonpressurized system, and will use the cap you mentioned. If the fasteners that hold the grille to the radiator are the DZUS type, then it is original.
rustyfarmall
10-04-2003 06:48:42
 Re: Re: Radiatorcap 1940 H in reply to rustyfarmall, 10-03-2003 14:26:44
Keep in mind also that if your tractor needed a new radiator after the pressurized systems became available, then that is what it may have now. The non-pressurized radiators were discontinued when the pressurized ones were introduced. I have seen several Hs with the later radiator, when they should have had the old type.
