IH 2500
Barnz
10-18-2003 21:29:39
Hello,
I have found an IH 2500 for sale. Can anybody tell me the pros and cons of this tractor. How many horses does it have? Does anyone have a picture of this tractor? Also, when where they built from?
Thanks,
Barnz
Jerry
10-18-2003 23:44:53
 Re: IH 2500 in reply to Barnz, 10-18-2003 21:29:39
Heres info on the 574-584 to give you some idea on what the 2500 may have for specs.
International Harvester
574
Manufactured: 1970 - 1978
Cost: $10,000 (1978)
Horsepower:
Drawbar: 45.1
PTO: 52.97
Engine:
Fuel: gas
Cylinders: 4
Displacement: 200.3 ci
Manufacturer: International Harvester
Transmission:
Forward: 8
Reverse: 4
Capacity:
Fuel (Gal):
3-Point:
Category: II
Tires:
Front: 6.50-16
Rear: 14.9-28
Weight: 4779 lbs
584
Manufactured: 1978 - 1984
Cost: $18,850 (1984)
Horsepower:
Drawbar: 47.4
PTO: 52.54
Engine:
Fuel: diesel
Cylinders: 4
Displacement: 206
Transmission:
Forward: 8
Reverse: 4
Capacity:
Fuel (Gal): 20
Cooling (Qt): 13.7
3-Point:
Category: II
Tires:
Front: 7.50-16
Rear: 16.9-30
Weight: 6685 lbs
Jerry
10-18-2003 23:37:21
The 2500 was the industrial version of the 574 tractor. The 2500B was the industrial version of the 584 tractor. Actually, all four tractor had the same bacic engine, transmission, and final drives, the front axles, tin, hydraulics, frame, rear tires and hitch were a few of the differences depending on the use for ag. or industry. They were both made at the Louisville, Ky. plant on the same production line at the same time. If I'm not mistaken, I believe the engine was around 60-62 HP. Others on the board will know for sure. I hope this helps.
Barnz
10-19-2003 12:06:00
 Re: Re: IH 2500 in reply to Jerry , 10-18-2003 23:37:21
Ah, thanks alot. But could you put a loader on a 2500? The ad says that it has a 77 inch bucket on it. And, where could I see a picture of one?
Thanks,
Barnz
Jerry
10-19-2003 22:56:57
 Re: Re: Re: IH 2500 in reply to Barnz, 10-19-2003 12:06:00
Yes on the 2500 or 2500B a laoder can be attached. In fact I think most of them came that way on the Industrial models. As for a picture, I'm not too sure where you may get one.
