Seat Shock
Allan
10-28-2003 03:35:17
Hi You Guys,
When did IH start putting the seat shock in front of the spring instead of behind on those old Hs and Ms? Was it in '52?
Or was it just a happenstance thing?
Also, can a guy buy the rubber bushings for the pivot shaft on the seat?
Thanks,
Allan
TDK
10-29-2003 10:57:32
 Re: Seat Shock in reply to Allan, 10-28-2003 03:35:17
Shock bushings from your local auto parts store will also work.Work and look as good as origional,and probably cheaper!
Larry in CO
10-28-2003 14:30:28
Allan,
The IH seat had the shock in front of the spring. The seat that had the shock behind the spring was an aftermarket seat by Monroe. One of my H's has the IH seat and the other one has the Monroe seat.
HTH Larry
rustyfarmall
10-28-2003 04:50:14
Those rubber bushings are available from your Case-I.H. dealer. Very inexpensive if I remember right. The hard part is getting the old pin and bushings out, but it can be done.
I have a 1950 H that has the shock in front of the spring, I can only assume that it is original.
Peabody
10-28-2003 06:20:41
 Re: Re: Seat Shock in reply to rustyfarmall, 10-28-2003 04:50:14
If you don't have an IH parts dealer nearby, you can get them from OEM Tractor Parts, 1-800-283-2122. $3.00/pair.
