560
Bill
01-03-2004 15:05:21
Need info please. aquired a 560 gas, runs good, low side torque out. When you clutch 560 in any gear it seems to stop under pressure. When you pull it out of gear it will free it up to roll. If you try to take it out of gear with pressure on any gear it will lock trans up. I have to take front trans cover off and pry gears back to get it to shift. Any help would be appreciated. Thank You
Aces
01-03-2004 18:11:39
 Re: 560 in reply to Bill, 01-03-2004 15:05:21
Bill evin if the low side of the TA is out the clutchs need to be adjusted right, that's you problem
Nebraska Cowman
01-03-2004 15:12:32
If you pull back on the torque lever can you shift then?
