Farmall H serial number
brad
01-12-2004 16:32:10
i looked at the serial code it didnot match up the numbers were fbh 113 and no years matched if some could help so i can find out the year of my farmall h .
thanks,
brad
Bill Smith
01-12-2004 19:57:55
 Re: Farmall H serial number in reply to brad, 01-12-2004 16:32:10
I agree, sounds like you didn't retrieve the complete number. If you can't retrieve it off the serial number plate, you might want to resort to the serial number off the right side of engine block (possibly the same number, not all of them matched but likely on the earlier H's I think) or you can resort to casting codes on major castings.
Nebraska Cowman
01-12-2004 16:43:59
you need more digits cuz they started with 501. scrape clean and look with a light and magnifying glass
Digger
01-12-2004 16:43:21
I would look again for make sure that you have all the numbers if so you have one of the first H's made and its made I think as early as 1939.
