230 Farmall Parts?
Brian Longeneck
01-30-2004 14:19:01
Can anyone tell me where i can find a distributor drive gear for a 230 Farmall with a four cylinder?
rebuilder
01-30-2004 15:26:43
 Re: 230 Farmall Parts? in reply to Brian Longenecker, 01-30-2004 14:19:01
Brian;
You need I.H. #353902R1. This is a distributor gear package which includes the gear, the split pin and two thrust washers. The gear has only one hole; you will have to drill the second upon assembly to "fit" to your distributor's shaft. Go to your nearest Caseih dealer, they should keep these in stock. I would guess the price to be $35-45 range. This gear fits all 4 cyl I.H. distributors. It does not, however, fit the delco-remy vertical mounted distributors or the newer prestolite/delco-remy distributors found on c-175/c-200 engines.
