Order Farmall Cub Parts Online
Changing throwout on Cub
Bob in Texas
02-02-2004 07:48:33
I need to change the throwout bearing and yoke on my Cub. I plan to break the tractor at the engine. I am assuming the shaft to the transmission is fixed as long as the bearing retainer on the front of the trans-case is in place. Am I correct? What else do I need to know? I don't want to pull the shaft and the gears fall off if that can happen.
wh
02-02-2004 11:35:40
 Re: Changing throwout on Cub in reply to Bob in Texas, 02-02-2004 07:48:33
if your graphite bearing is gone and you replace with same type you will need to change the pressure plate. the fingers on it will chew up the new graphite bearing. i learned this the hard way. could not see a thing wrong with plate and new bearing lasted 2 days.
