Farmall H Weight
Allan Friede
10-18-1999 19:10:19
I have to haul a Farmall H tractor about 300 miles. I would like to know the weight so I can determine if my trailor is big enough.
I'm sure someone know and I would appreciate an e-mail.
Thanks
Allan Friede
jakee
10-18-1999 20:21:21
 Re: Farmall H Weight in reply to Allan Friede, 10-18-1999 19:10:19
between 4000-4500
Farmer Bob
10-18-1999 20:20:32
Allan,
Just sent you an email...will post here for others who may need it- IH Tractor Data Book says the H weighs in at 3725 w/tricycle front and 3980 w/wide front.
ken b
10-25-1999 20:22:43
 Re: Re: Farmall H Weight in reply to Farmer Bob, 10-18-1999 20:20:32
weight of mine at a pull sun was 1910 with 2 batt and my big 165 on it
ken b
10-26-1999 20:06:01
 Re: Re: Re: Farmall H Weight in reply to ken b , 10-25-1999 20:22:43
I am so sorry after I look today and seen my tractor weight was 3910 sorry ken
Ludwig
10-19-1999 07:29:47
Figure a Regular weighs about the same or a little less right?
I got no wheel weights, fluid in 1 tire, 1 steel wheel, no water in radiator, not much left of front tire.
BIG trailer, but I'm gonna pull it with the Dakota. Dakota is rated for 7K (I think) with the towing package and 318 I've got.
Think I can make it?
Farmer Bob
10-20-1999 00:43:38
 Re: Re: Re: Farmall H Weight in reply to Ludwig, 10-19-1999 07:29:47
Ludwig, Maybe/maybe not! Remember the trucks towing rating is gross including the weight of the trailer as well as the tractor. I pulled my M on a Ryder auto transport behind my Ranger (4.0 V6) with the tow package. Weighed the rig at a truckstop CAT scale and trailer and tractor was 6785lbs. Drove about 200 miles and decided that if I wanted a truck left I should stop and rent the Ryder truck to pull the trailer. Glad I did as I never would've made over the Rockies going from Iowa to Washington ST.
Ludwig
10-20-1999 06:26:41
 Re: Re: Re: Re: Farmall H Weight in reply to Farmer Bob, 10-20-1999 00:43:38
Fortunately 1. My tractor is smaller than yours, 2. My truck is bigger 5.2 V8 Dakota, and 3. The trip from northern Maine to southern Maine is alot flatter than trying to make the Rockies. I will post an update after I'm through.
T-Tim
10-18-1999 20:39:35
Don't forget to add for rear/front wheel weights or fluid filled tires.
Charlie V
10-18-1999 21:47:12
 Re: Re: Re: Farmall H Weight in reply to T-Tim, 10-18-1999 20:39:35
Fluid can weight up to 300 pounds per tire, I just hauled a Farmall " H " 75 miles on a 8000GVW trailer with fluid in tire's and it never moved. Chained front & rear wheels & put a web strap across center of tractor. This trailer is 84 inches wide and had to suck the tire's in next to the tractor to get it on, had 2 inches to spare, so your trailer needs to be at least 80 inches inside fender-well to fender-well or she won't fit. Also be sure you get rear wheels in the center of the axle and put weight onto hitch or she sway all over the place. Chain her good, drive at a safe speed and stop after about 40 minutes and check all your chains and you will have a safe and enjoyable trip
MrG:Can't add much to that
10-19-1999 08:20:20
 Re: Re: Re: Re: Farmall H Weight in reply to Charlie V, 10-18-1999 21:47:12
But do NOT try and use OD if your truck has it, stay in direct Drive or you'll tear out a transmission in a hurry.
Joe
10-18-1999 21:41:26
I just weighed my 48 H. It has rear wheel weights and fluid in the rear tires.It's a narrow front and weighs 4600 lbs.
