M, Thermosyphon, information wanted
Adam Whitson
03-12-2004 14:12:47
I am curious about the Thermosyphon system. Anyone know any sites that have information on the Thermosyphon system? I have seached the archives and gained some info. Just made me even more curious.
ABW
Bill Smith
03-12-2004 18:40:38
 Re: M, Thermosyphon, information wanted in reply to Adam Whitson, 03-12-2004 14:12:47
If the M in your post title stands for Farmall M, I thought they all had a water pump. Anyways, I've never seen one that didn't but maybe there is something I don't know about. Not sure what kind of info you are looking for about the thermosyphon cooling system, but it is a basic set up with not to much info to know about. A thermosyphon system does not have a water pump and most likely not a thermostat and ussually unpressurized. Hot air rises and hot water does the same. On that concept is how the water circulates up out of the engine block when heated and creates the circulation. The circulation causes the water to go down through the radiator (cooling off) and then re-entering the block replacing the heated water through the circulation process. Pretty simple.
