44 M lift-all hyd pump
Brad Kimball
03-15-2004 18:09:00
Today we discovered the pump has a crack in it and is shot. Any ideas where to get one to replace it? One that has good pumping ability?
TDK
03-15-2004 20:55:28
 Re: 44 M lift-all hyd pump in reply to Brad Kimball, 03-15-2004 18:09:00
Brad, I have one that could be rebuilt or used for parts, if you intend to fix the one you have. Send me an e-mail.
Andy Martin
03-15-2004 19:04:32
Crack in reservoir or pump? Reservoir is easily fixed.
If pump is a little loose you can usually take a shim out. They don't get opened up very often and most still have shims (very thin)
Brad
03-16-2004 18:13:28
 Re: Re: 44 M lift-all hyd pump in reply to Andy Martin, 03-15-2004 19:04:32
Its a crack in the pump body. I can send pictures.
Thanks for your replys
John *.?-!.* cub owner
03-15-2004 18:50:59
Try www.jptractorsalvage.com probably will have to email or call them.
