TA Question
bones
03-17-2004 07:13:54
I am having some problems with the TA in my 706. I am told that I need to pressure check the TA. How do I go about doing this.
RB
03-17-2004 10:37:28
 Re: TA Question in reply to bones, 03-17-2004 07:13:54
Remove the plug at the botton of the MCV (mutiple control valve) its o-ring thread, install gauge of 300lb. or more. Should read at around 225lbs. Note; pressure at engine idle, at 1200rpm. with TA forward and back. Also turn steering wheel back and forth and note gauge reading. Normal TA scenarios; leakage inside TA, weak pump (won't show on pressure test) external linkage binding or damaged or misadjusted. Good luck!
Bones
03-17-2004 10:46:07
 Re: Re: TA Question in reply to RB, 03-17-2004 10:37:28
Thanks RB for the help.
