Should bearings be replaced as a matter of course?
Brad
03-23-2004 19:01:18
I have my 46 A completely taken apart and have been replacing all the oil seals. I have found only one bad bearing, in the belt pully housing. All other bearings look good. My question is; now that I have the differential shaft housing and drop axles taken apart would it make sense to replace all bearings in the rear end, even the ones that still feel good? What are your thoughts on this aspect of restoration?
KeithF
03-25-2004 09:52:42
 Re: Should bearings be replaced as a matter of cou in reply to Brad, 03-23-2004 19:01:18
My experience with a Super A is that too often the final drive unit has little or no oil left in it and the outboard bearing on the axle shaft at the top of the final drive is starved of oil and is worn and loose. I replaced those on both sides. Look them over closely.
lee
03-24-2004 06:29:18
You might also consider how badly you had to beat them up in the teardown process.
Haas
03-24-2004 05:23:51
If the bearings have no play, no rust, and turn freely and smoothly, no need to replace them.
Roger WI
03-23-2004 19:16:51
Brad, You could do that if you have a lot of money. I usually only replace the bearings that are either rusted or don't turn freely (rusty ones don't turn freely). I also look at the bearing location and how much it is loaded or used. It also depends on your intent in restoration. If you intend to use this tractor heavily then it may make sense to replace the bearings, especially the ones that turn at a higher rpm. For example, I haven't been replacing bearings in the belt pulley assembly on my Farmall H; because I don't use that except for show. Roger
dlp
03-23-2004 19:12:20
Here's my 2 cents worth. I say leave them alone if they are still good. The bearings you buy may not be as good as the originals. This is an area that you get what you pay for.
