how to check differential gear oil
bob missouri
04-07-2004 23:45:20
This may sound dumb to some of you,but i recently purchased a farmall H and cant find anywhwere to check gear oil level in rearend and tranny. Whats the secret to checking gear oil? Don't have a service manual.
Wardner
04-08-2004 12:41:43
 Re: how to check differential gear oil in reply to bob missouri, 04-07-2004 23:45:20
There is a check level plug half way up on left side of rear casting. Tranny and rear end share the same oil. It takes ten gallons.
Get yourself an operator's manual. Parts books are very helpful too.
Wardner
04-08-2004 12:52:57
 Re: Re: how to check differential gear oil in reply to Wardner, 04-08-2004 12:41:43
Ooops, looks like I double posted after a 12 hour interval.
Ya, it does hold six gallons. I always buy five gallon buckets and the last time I changed oil I bought 10 gallons. Forgot that I didn't use it all.
jal-SD
04-08-2004 08:49:29
The idea of changing it is a good one. I've been around H's all my life & know that C's, H's & M's all like to collect water in the rear ends. I'd be suprised if you don't have a gallon or two of it in there. After it sets overnight (or longer) loosen the big plug under the back end (make sure the swinging drawbar is out of the way) & GENTLY screw it out by hand. Push in on it so when you get through the last thread, you can tip the bottom away from the casting. Do this when its rather cool out, so the grease is stiff. I'd be willing to bet big $$ that you get a lot of water out of there before any grease starts to run. Put the plug back in and then check the level. If the grease that runs out looks good-leave it-if not, change it. (My $0.02 worth. jal-SD)
Dave in Texas
04-08-2004 08:08:54
Here is a link to an online Parts Manual for the H.
http://www.cleancomputes.com/Cub/H%20-%20HV/index.html
Dave S
04-08-2004 05:33:15
The oil level plug is on the left side about half way up the transmission case around the clutch pedal . It holds 6 gal.
williamf
04-08-2004 05:30:28
There's a square head plug (half inch head, I think) close to the clutch pedal.
Unless you're certain it was recently done, you ought to change the gear oil. For six gallons of 90wt you can learn a lot about the condition of the machine.
Owner's Manuals are about thirty bucks from the Tractor Manual link top left of this page. Not a bad investment, either.
Wm
OBie nh
04-08-2004 02:46:59
I may be wrong but my 41 H takes 6 gallons
Wardner
04-07-2004 23:55:06
bob missouri
04-08-2004 18:59:19
 Re: Re: how to check differential gear oil in reply to Wardner, 04-07-2004 23:55:06
Thank you all for the information. I believe that the best thing is change gear oil as has been suggested. thanks, Bob
