Super A Hydraulic oil change??
bruce hively
04-08-2004 06:09:14
Okay, I'm a newby at Red Power.
Getting to know my '51 Super A and getting it ready to work.
I'm changing out the hyd. oil because it may be contaminated by water. According to the manual, after draining, re-fill, remove drain plug and work levers 10-12 times forward and backward, replace plug and refill.
My question is How do you accomplish this? Is there a "special trick or plug" to use? By the time I get to maybe 6 motions on the levers, all the fluid is already out!
Thanks,
Bear in Apex, NC
BOB
04-08-2004 17:51:29
 Re: Super A Hydraulic oil change?? in reply to bruce hively, 04-08-2004 06:09:14
Bruce make sure you have all cylinders retracted when you check hydro oil. then top them off
Jim Becker
04-08-2004 07:23:47
You should remove the filler plug before cycling the system, not the drain plug.
bruce hively
04-08-2004 12:19:02
 Re: Re: Super A Hydraulic oil change?? in reply to Jim Becker, 04-08-2004 07:23:47
thanks Jim, I went back and re-read the manual; sure enough it said filler plug!
I feel like a *&%$! dummy!
thanks again
