IH 240 Proofmeter
Brian in Penna.
04-11-2004 17:34:07
Do you guys know where I could find a tachometer for a utility 240? It is a 4spd. transmission and is a different meter than what the row crop model has. Thanks!!
Wardner
04-12-2004 07:42:09
 Re: IH 240 Proofmeter in reply to Brian in Penna., 04-11-2004 17:34:07
The only difference is probably in the face of the tach. I don't know anything about 240s but the various models may have a different gearing in the top speed or ratios through the gears. The "PTO 540" line is probably located at the same RPM.
You should contact a rebuilder to see if they have the face you need. It is unfortunate that the IH parts book does not "explode" the tachs so that we can identify the various faces.
