Farmall H restoring questions
Bob G
04-12-2004 14:31:14
it is a 1942 Farmall H and just got a decal pack. I need to know where the one with O D B goes, LH D B, the gear shift pattern, one that says BE CAREFUL do not make short turns at high....., and "do not attmept to pull when drawbar is removed drawbar.....
plus, the air cleaner, radiator cap, fuel cap, and coil colors, black or red. thank you
CNKS
04-12-2004 17:58:19
 Re: Farmall H restoring questions in reply to Bob G, 04-12-2004 14:31:14
Guy Fay's Letter Series Tractor book gives exact factory specs, you don't have to guess. Having said that, the the ODB or LHDB light switch decal goes on the light box adjacent to the switch, the one you use depends on whether you have 3 or 4 position switch, which depends on whether you have a cutout relay or voltage regulator. The high speed turn decal is centered on the top of the gas tank 1/2 inch in front of the gear shift decal. The top edge of the gear shift decal is centered on the gas tank 18 1/2 inches from the rear edge of the hood (or 18 1/2 inches from where the hood is supposed to lap onto the gas tank). The drawbar decal is centered on the rear of the seat pan 1 inch below the lip (this is mislabeled in Guy's book). The air cleaner is red, fuel cap red, I prefer the radiator cap unpainted (don't care how it was from the factory), original coil was red -- the new ones look ok black, unless you get a original style one, then it should be red.
Ryan George
04-12-2004 15:29:29
the gear shift pattern i believe goes on the fuel tank, and one set of letters goes below the light switch to indicate the position. i would recommend going to www.farmall-h.com. that website is dedicated to the farmall h and you will probably be able to find what you need there.
