Farmall H water Jacket Cover replace??
Brian
04-13-2004 02:51:46
I was wondering if there would be any problem with replacing the water jacket cover (on the manifold side of a farmall H block) with a piece of flat Iron or sheet metal. The one that is there is all rusted out. Will putting a piece of flat metal over the spot cause any problems??? Thanks for any help. Sincerely
Brian kansas
Dave S.
04-13-2004 05:35:49
 Re: Farmall H water Jacket Cover replace?? in reply to Brian, 04-13-2004 02:51:46
I would use a plate with the baffles, especially if you are going to have any load on the engine.
Mike at Steel Wheel Ranch has them for around $25. www.steelwheelranch.com Ph# 785-548-7437
rustyfarmall
04-13-2004 04:48:00
The baffles on the inside of the original are there to direct the flow of water in between the cylinders, without those baffles, you run the risk of overheating the two center cylinders. Replacement covers are available from many places. Try your Case-IH dealer first.
