broken tooth on rotor
bill from senec
04-18-2004 15:55:53
hi , i have restored a 1948 farmall cub but had problems starting it up and keeping it in time so i pulled out the magneto and found out it had a broken tooth on the rotor the the magneto is a J4 magneto part # J4046498 and is not battery ignition i have been looking everyware for this type of rotor with gear like teeth on it is there someone that can tell me ware to get this tpye of rotor or can you use a replacement type rotor with out the teeth on it as for the magneto it is in great shape so i wound like to keep it as close to orignal as i can any help wound be very appreciated thanks bill
John *.?-!.* cub owner
04-18-2004 18:58:50
 Re: broken tooth on rotor in reply to bill from seneca , il, 04-18-2004 15:55:53
Part number is 351692R91. Most dealers have or can get them. Also available from www.cngco.com,as well as several magneto repair places. Also www.brillman.com or www.magnetoparts.com
BILL
04-18-2004 19:51:28
 Re: Re: broken tooth on rotor in reply to John *.?-!.* cub owner, 04-18-2004 18:58:50
hi john, your right thats not cheap but i have found that out when your trying to restore a old cub thanks again bill
04-18-2004 19:14:22
hi john, thanks for your help once again you truly know everything about farmall cubs you helped me out a great deal with the flywheel too thanks very much bill
04-18-2004 19:01:05
Forgot to mention, they ain't cheap. About $25. I'd buy a new IH cap along with it. I once tried to save money by using an aftermarket cap and broke a NEW rotor.
