TD-25-C
Bruce Hedge
04-21-2004 08:25:33
I have a 1968 International TD-25C Crawler with a blade & winch. Is there someone with experience who would know the answer to the following. The question is: If the input pump runs dry and fails does it create a gear whine as the converter loses pressure and the dozer stops ( my theory after inspections is: all of this is due to a line getting plugged--due to water in hydraulic tank behind winch which plugged the line filters when the oil/water mix mixed & gelled to a substance like latex paint). And further does the damage probably stop at the converter input pump. Thank you in advance if you have any input.
billy
04-21-2004 19:53:47
 Re: TD-25-C in reply to Bruce Hedge, 04-21-2004 08:25:33
if the torque converter charge pump stops pumping oil it is normal for it to quit pulling. you have a suction filterthat is stopped up.the resevor is not the tank it is the transmission and steering case. sounds like you need to drain and change filters and clean suction filter.. if it runs long without oil it will damage the pump . hope this helps.let me know.
