where to find small, cheap alternator for H Farmal
aaron
04-21-2004 08:54:26
I have the original 6V equipment for an H Farmall, but becuase I like to run alot of lights I will be converting to 12V. I have done this before on an M. Just curious if anyone knows of a tiny, cheap alternator that will fit under the hood of an H on the original generator bracket.
Thanks,
Aaron
Greg
04-21-2004 19:51:19
 Re: where to find small, cheap alternator for H Fa in reply to aaron, 04-21-2004 08:54:26
I just replaced a Delco 3 wire alternator on my IH 364 diesel that had been previously converted. You can buy the Autozone "house brand" with a 1 year warranty for $20.99 or a lifetime warranty for $36.99. I asked them to test it before I left with it. They did, it was putting out great and looked good to boot.
Tom W
04-21-2004 16:19:44
Auto Zone is the cheapest for rebuilt alt. $30 for a delco
Dave_Id
04-21-2004 09:12:49
I have placed the standard size Delco wire alternator under the hood of an H. I flipped the bracket around, and it had to be mounted right against the valve cover using a shorter belt. I had to slip the belt over the pulley first, then mount the alternator.. You can get used GM alternators at your local bone yard.
Rudi
04-21-2004 08:58:04
third party image
Aaron:
I know the page below is not H orientated but Cub orientated, however, a lot of Cubs are being converted to 12v - why I do not know, but they are.
Most are using the Hitachi alternator which fits under the hood of a Cub, so it should fit under the hood of an H.
Click the link below, then Maintenance Tips and Techniques then 12 Volt Conversion with a Hitachi 14231 Alternator.
Hope this helps.
