H question
Bill Brauch
10-25-1999 17:55:54
How can I determine the year of an H that has the ID tag missing from the bellhousing? The owner thinks it is a 44, because he bought it in 50.
Pappy
10-25-1999 22:12:19
 Re: H question in reply to Bill Brauch, 10-25-1999 17:55:54
We bought an H last summer without a tag. Look on the right side of the block, toward the front, above the distributor. There should be a number stamped on it. In most cases, this number is the same as the serial number. Not every time, though.
Bill Brauch
10-27-1999 18:19:58
 Re: Re: H question in reply to Pappy, 10-25-1999 22:12:19
I looked there, and it has the number 63177, which seems to indicate 1941. The engine is stuck, but I have high hopes of getting it to run again. The rest of the tractor is in pretty good shape, if you ignore the surface rust all over the outside.
RED Blooded
10-25-1999 19:08:03
Look for casting codes on the tractor.They should read something like 12-6-K.Post those numbers.They will vary on different parts.
