M W clutch on an M
Brad
05-07-2004 12:02:49
A friend of mine is looking for clutch plates for an M & W PTO clutch on an M and is having no luck. He says they're steel plates, not fiber. Does anyone know anyone who may carry these? Thanks alot.
Kelly C
05-07-2004 21:28:19
 Re: M W clutch on an M in reply to Brad, 05-07-2004 12:02:49
There are 2 types of disks in the clutch. Metal spacers that gear to the bull gear and fiber disks that gear to the brake drum.
The metal ones you can get made at any machine shop.
The fiber ones are a little harder to come by.
Here are the specs for the one for a H. The ones for the M are the same just bigger.
The clutch disc you are looking for is a 121R which is obsolete. I do
have a drawing of that particular part. The specs are 13/64 thick, 8.25
OD, 5.5 ID, 6/8 D pitch on the teeth, 48 teeth, 20 degree pressure
angle. Some other info I have says Raybestos 500B and Fibre Plate Mat.
R500B Cure Co. Thats all I have, hope is some help to you.
Andrew-M&W Tech Service
I am sure if you call Andrew at M&W he can get the specs for the M. 1-800-221-2855
