h will not run need help
Bruce
05-08-2004 07:57:58
Hi having a little trouble with my h was riding along and it just die.Check the fuel clean the bowl,cleaned the filter on the fuel line before the carb,unhook the line at the carb and fuel run out good there.Took the needle out of the carb and fuel run out good there.So im thinkinf its electrial.Tryed a different coil it has a distrbritor.No spark willnew point and condenser fix the broblem need help thanks
Scott
05-08-2004 10:42:02
 Re: h will not run need help in reply to Bruce, 05-08-2004 07:57:58
Bruce, You should also check to make sure you have current from your ignition switch to the coil. Could be a bad switch, wire, or connection someplace. Also check or replace your cap and rotor. Also the float in the carb could be sticking. When it dies loosen the bowl drain and see if gas comes out. A needle and seat dosen't cost much so it may be a good idea to replace them.
Jeff In Ontario
05-08-2004 08:12:41
I would change points, condenser and plugs all in one shot. Are you sure that the new coil is good??
