560 hydraulics
bryan
05-31-2004 17:30:47
I am stumped. The hydralic on my 560 are weak. I have to have the tratctor at a high rpm in order to lift any thing. If i slow the engine down while attempting to lift something it will start to lower back down. I have changed the filter, new oil, it took the suction line off to make sure it was not plugged or leaking. Redone the entire regulator and safety block. I think the only thing left it the pump. I am taking it out tonight. What is the real problem?
Chris Brown
06-01-2004 06:33:43
 Re: 560 hydraulics in reply to bryan, 05-31-2004 17:30:47
Sounds like a leak somewhere inside. Does your power steering work at low speeds?If the p/s is ok then I would say it is something besides the pump.
bryan
06-01-2004 07:33:40
 Re: Re: 560 hydraulics in reply to Chris Brown, 06-01-2004 06:33:43
It does turn harder when it is at a lower engine speed
IndianaDan
05-31-2004 21:27:58
Sure could be the pump. I was wondering though, could it be the cylinder? Do you have an implement you can raise with one of your remotes? This could provide a good clue. If the remote operated implement drifts down too, I would look at the components common to both.(pump etc...)
Good Luck.
Joe Evans
05-31-2004 20:02:01
bryan: since you rebuilt the regulator block, the only thing left to do based on the symptoms you describe is to replace the pump.
If you overlooked the O-ring seal on the regulator piston during the block rebuild, it will not produce the symptoms you describe IF your pump is A-ONE.
Steel Wheel Ranch has rebuilt pumps for $250. They are a breeze to change out--IMO one of the good things IH did for pump serviceability. Just went through a hydraulic system rehab on our 460. For a complete report, go to our web site and read about all the hair-pullin' I went thru to resolve a bad hydraulic system. You'll find a link to Steel Wheel Ranch there, too.
bryan
05-31-2004 20:36:45
 Re: Re: 560 hydraulics in reply to Joe Evans, 05-31-2004 20:02:01
The only problem i have about getting an rebuilt pump is who ever the idiot was who welded the pump gear to the shaft should get a swift kick in the you know what. Is it possible to get the gear with a rebuilt pump?
Chuck's Repair
05-31-2004 19:12:55
Don't overlook the o-ring around the piston in the hydraulic check block.that is a common failure in that tractor and is easy to fix for less than a dollar and about 10 minutes of your time.
bryan
05-31-2004 20:11:07
 Re: Re: 560 hydraulics in reply to Chuck's Repair, 05-31-2004 19:12:55
I did replace the o ring on the piston. Thanks
Harley1983
05-31-2004 18:02:26
Probably the pump. It's old enough to need replaced. New one at IHC is around $400.00. Take-out, bench tested at Cook Implement, Clinton, Mo. $250.00, Harley
bryan
05-31-2004 18:36:38
 Re: Re: 560 hydraulics in reply to Harley1983, 05-31-2004 18:02:26
if i sent it to cook implements what do you mean bench test and $250
Novel Idea Guy
06-01-2004 09:25:06
 Re: Re: Re: 560 hydraulics in reply to bryan, 05-31-2004 18:36:38
"Take-out" meaning removed from a parts tractor. Used, not rebuilt.
"Bench tested" meaning the "take-out" pump was tested to make sure it was good on a bench.
You don't send your pump anywhere, unless there is a core charge and you want your money back.
