Order Farmall Cub Parts Online
cub compression
bgud
06-13-2004 09:07:12
I am working on a cub and was wondering what the normal compression is for this engine. Any help would be appreciated. Thank you
Bigdog
06-13-2004 14:11:04
 Re: cub compression in reply to bgud, 06-13-2004 09:07:12
More important than the readings is that they be close on all 4 cylinders. Anywhere near 100 is desirable. I've seen them run well @ 70 to 80 as long as all readings were witin 10% of each other. Newly rebuilt engines usually run 100 - 120.
bgud
06-13-2004 19:04:25
 Re: Re: cub compression in reply to Bigdog, 06-13-2004 14:11:04
Thanks for the info. Mine has only gone 50-60 psi of compression. I was thinking that was pretty low just wanted to make sure. I'll have to dig into it a little further.
