How to polorize 6 volt generator?
Bruce
06-19-2004 15:57:42
I have a 1940 Farmall H that was given to me pretty much in a basket. My brother and I have got it back together now. I bought a 6 volt generator for it and put it on. I read that you have to polorize the generator. Can anyone tell me how to do that? Also I had it running already, could that hurt anything?
Thanks,
Bruce
steve
06-19-2004 19:29:55
 Re: How to polorize 6 volt generator? in reply to Bruce, 06-19-2004 15:57:42
polarizing just tells the generator and voltage regulator which end is + and which is -. your "A" on generator connects to the "G" on the regulator. "B" on the reg connects to the battery. --- you jumper the "B" to "G" terminals on the reg prior to starting the tractor so the reg sees which way the voltage is running, then start the tractor. already starting probably dont hurt regulator. if you cant get to the regulator, then touch "A" on the generator to the battery terminal. (not the grounded one)
Bob
06-19-2004 19:27:34
It is VERY advisable to polarize before starting, but there's PROBABLY better than a 50% chance you didn't hurt anything by starting it.
I assume you have the battery connected up in the original POSITIVE GROUND manner?
To polarize, with the engine OFF, momentarily jumper the terminal at the regulator that has battery power to it (typically labelled "BATT") to the regulator terminal labelled "A" (or GEN) that connects to the "A" terminal on the generator.
