M steering bolster drain ??
Brad
07-04-2004 17:49:10
Is there a plug to drain the bolster? What kind of oil can I put in the bolster??
Thanks
little john
07-05-2004 04:53:45
 Re: M steering bolster drain ?? in reply to Brad, 07-04-2004 17:49:10
And some people use grease. I just packed grease around the gears in mine.
TDK
07-04-2004 23:05:47
There is no drain. Remove the 5 bolts on the housing cover to fill.If there is anything in it, you'll have to use a suction gun to remove it. Manual says SAE 80, but you can get some gear lube from a Snapper dealer that works very well. Some people also use STP engine oil treatment.
