What Year?
Bill
07-05-2004 10:47:54
I am trying to find out the year of a Farmall A It has no electric starter and no right angle pto. There is no sn. plate on the seat bracket is there another place I should look?
gene b
07-05-2004 20:26:39
 Re: What Year? in reply to Bill, 07-05-2004 10:47:54
Are there four holes in the seat bracket on the pto lever side? If not four holes there it should be mounted on the pedal guard between the two brake pedals. Belt pulley assy were extra so that is why yours is not there. Does your hood have j-hooks to hold in place or the 1/4 turn slotted hex head? There will be a code dating on the tranny housing by your left foot number*number*letter these will tell when housing was cast. There is lots of other ways to determine yr built but these are the easiest.
Jim Becker
07-05-2004 11:59:31
Look on the sheet metal shield below the front edge of the platform.
You can also check the engine number, stamped just below the #1 spark plug. If it is the original engine, the number may match the serial number.
