conformatic pistons
brent
07-06-2004 04:23:45
I tore into a super M, to rebuild, The pistons are conformatic (aftermarket I presume), Does anyone know where I can get new rings for these pistons? Thanks for your help
justin
07-06-2004 05:28:02
 Re: conformatic pistons in reply to brent, 07-06-2004 04:23:45
On the side of the piston or inside the skirt there should be a part number that will start with GE. Post it, and I will be able to tell you what rings you need.
brent
07-06-2004 06:57:19
 Re: Re: conformatic pistons in reply to justin, 07-06-2004 05:28:02
the part number on the pistons is GE 300, thanks
justin
07-06-2004 09:10:52
 Re: Re: Re: conformatic pistons in reply to brent, 07-06-2004 06:57:19
The GE-300 piston uses 3 3/32 compression rings and 1 3/16" oil ring.
nebraska cowman
07-06-2004 05:15:38
as long as you know the width and number of rings you should be able to get them anywhere.
