Generator
Brian
07-23-2004 17:56:03
Trying to get generator system working on my WD6. Gen checks out OK and cutout works. I can get 13.2 volts at half throttle with field wire hooked up to regulator. With the field wire going to the light switch like the diagram shows I don't get any charge and no voltage going through the field wire. Hooked to the field terminal on the cutout the wire has about 4.5 volts. Do these numbers sound right. Hope to get this working well enough to run a couple lites. Thanks for any pointers.
Brian
parts man
07-23-2004 19:56:52
 Re: Generator in reply to Brian, 07-23-2004 17:56:03
Brian, your light switch has to have a GOOD ground for the gen to charge with the field wire hooked through the switch.
