Want to go pulling, timing an 806 injection pump
Billy
07-24-2004 06:42:31
Bought a used roosamaster pulling pump for my 806. Timed it as he directed at 22 degrees BTDC on compression stroke. Tractor will run on either, but slobbers black unburned fuel out of the exhaust. Question - is it timed too late? Any ideas? Thanks
Chris Brown
07-24-2004 20:25:35
 Re: Want to go pulling, timing an 806 injection pu in reply to Billy, 07-24-2004 06:42:31
Don't know,can't tell ya. I have timed a few pumps by the marks and the darn thing would'nt even run. Since it runs(be it poorly) turn the pump while running,turn it to where it smooths out and runs clean and just starts to rattle like a diesel.Then check the timing marks and see what it is set at. I used a huge pipe wrench and a thick rag to cushion the wrench on the pump,that's the only way I could hold the pump and tighten the bolts by myself.
