FARMALL h carb
Bruce
07-25-2004 08:10:57
I have a farmall h that was not running when I bought it. It runs now but not well. I was wondering if the carb is correct for this h. I have had a few people tell me the carb looks wrong. The h serial number is 305194 the number on the carb is 50981DC. THANKS FOR YOUR HELP
The Red Baron
08-02-2004 07:59:11
 Re: FARMALL h carb in reply to Bruce, 07-25-2004 08:10:57
test
The Red Baron
08-02-2004 07:57:06
test
CNKS
07-25-2004 14:08:38
Your carb is correct. 50981 DC is the gasoline carb. The people who say it looks small may be confusing it with the Super H carb, which is similar to the one on the M.
little john
07-25-2004 13:39:01
I'm not sure, but you might have the small carb that was on the distillate engines. My "H" has the same, and it has a D in the number on that little round plate on the carb. However, mine runs OK with the small carb, at least with the use I give it. That's mostly driving around with no load of any kind.
Jeff In Ontario
07-25-2004 13:32:12
I'm lost when it comes to #'s on carbs. Can you post a picture of this carb? That would be sure to get you an answer! If you haven't got a picture and no one else can help, then I will check my carb tomorrow and let you know.(My H is # 353066 )---Jeff
