Order Farmall Cub Parts Online
Cub Serial number
Beeler
11-07-1999 01:30:20
I just purchaed an IH CUB. I was told that the serial number was on the steering housing, but I have found none. I did find several numbers on the left side of the engine. I think this is the serial number CUB M 16349, this was located just under the valve ajustment plate near the rear. the other numbers on the block are 251341B1 and 1-16-R. Also numbers on the frame behind the block 130R and 3516868RI. All the parts are painted red except for the grill which is white, I think this is the original paint. Thanks
sammy the RED
11-07-1999 04:20:11
 Re: Cub Serial number in reply to Beeler, 11-07-1999 01:30:20
You have a 1948. The grill should be red.
Beeler
11-07-1999 04:27:50
 Re: Re: Cub Serial number in reply to sammy the RED, 11-07-1999 04:20:11
Sammie the Red, so the CUB# is the serial number? While we are at it, where is the best place to get the correct color red for an IH and what type?
sammy the RED
11-07-1999 04:38:54
 Re: Re: Re: Cub Serial number in reply to Beeler, 11-07-1999 04:27:50
I got year from casting code, *1-16-R* I use IH 2150 Red from local Case/IH dealer. Others use automotive type paint,cost is a lot more. A good site for cubs is at ATIS, but people are haveing trouble getting on at the moment.
