Fast hitch
Big T
08-15-2004 04:01:18
Looking for a fast hitch set up for a super c in michigan. How much are they worth?
Russ
08-15-2004 15:49:25
 Re: Fast hitch in reply to Big T, 08-15-2004 04:01:18
Farmall Super C; I used to have a JD B and if all works out I will get a Farmall Super C when the time is right. I know a guy 20 miles from here claims to have 17 of them, some running others stuck. I would put a lot of effort into mounting up a 3 PTH. Lots of implements will then couple up in a few minutes. Just my 2 sense.
kjm
08-15-2004 14:40:40
Big T, I like my fast hitch, but if I was going to buy a hitch it would be a 3 point(about 500.00 new) it would be cheaper in the long run because 3 point imp. are a lot easyer to find.
BillWV
08-15-2004 10:54:57
There is a partial SC fast hitch on e-bay right now. I'm not associated with it in any way, just saw it while browsing Super C parts a while ago.
Good luck,
Bill
Hugh MacKay
08-15-2004 08:10:21
Big T: My suggestion is first get a parts diagram and listing. Without that it is quite hard to be sure you have it all. You see fast hitches listed between $300. and $500., not bad if you have it all. If you end up having to spend another $300. for missing pieces, starts to get expensive. I've seen a few of these with the hardest to find parts missing. In fact I have one (not for an SC) bought in 1992, I knew there were parts missing. I have not found them yet. I have seen the parts at unreasonable prices.
