cnksstan Update on super A
blackie
08-18-2004 17:31:09
I thank both of you for your expert advice.After removing front grill cowling and rad. as well as water necks and brackets , I discoverd how to adjust belt for fan.It was some loose but did not see a way it could be adjusted.I am nearly 60 years old, been doing mech. work on diff. things in my life, would not have thought there was a cooling system without a water pump to circulate water. So you can see This ole man learned a little today.I did go ahead an flush system with pressure washer .Except for a few dirt doblers in fins of rad. it looked good.I will get a new belt at old INT. dealer tomorrow and see if thoese gaskets are still availble or make them my self.Thanks fellows you were a big help.BTW I use this tractor for planting and culvating and raking hay.
