What year is this Farmall H?
Brenda G. Hulse
08-21-2004 12:10:52
We have a farmall that we thought was a 1947. The serial No. on the left side on a plate has 37856. would this be a different year than we thought? The tractor has been in the family since about 1954 or 1955.
MagMan
08-21-2004 13:35:53
 Re: What year is this Farmall H? in reply to Brenda G. Hulsey, 08-21-2004 12:10:52
Are you sure you are not missing a # in that serial. how about the Motor serial does that match? Right side above the mag or distributor a small raised block with the #.I Cant remember if its in the front or rear of the motor on a H. JON
Brenda G. Hulsey
08-21-2004 14:30:48
 Re: What year is this Farmall H? in reply to MagMan, 08-21-2004 13:35:53
Thanks Jon, The # was in front on the motor. It matched the one on the plate. Poor tractor hasn't had this much cleaning on it for a long long time! Hope it'll still run after scrapeing the gunk off it! So I guess this makes it a 1940. Great! I guess I'd better check out the 48 cub and see if that the year for it. Brenda
Allan in NE
08-21-2004 12:32:08
Brenda,
Looks about like a 1940 model to me.
Allan
Brenda G. Hulsey
08-21-2004 13:18:50
 Re: What year is this Farmall H? in reply to Allan in NE, 08-21-2004 12:32:08
Thanks Allan, Is there any other way we can be sure what year it is? As you can guess I'm new to all this but I would really like to have more information on this tractor.
rustyfarmall
08-21-2004 14:04:21
 Re: What year is this Farmall H? in reply to Brenda G. Hulsey, 08-21-2004 13:18:50
Another way to determine the year is by looking at the casting codes, which will appear on virtually every part of the tractor. The code will appear as a three digit number. An example would be 2*16*J The letter J represents the year, in this case 1940. The other two digits will be month and day, respectively. The codes on your tractor will not all be the same, but should be very close. Let us know what the codes are on your tractor.
Brenda G. Hulsey
08-21-2004 14:41:34
 Re: What year is this Farmall H? in reply to rustyfarmall, 08-21-2004 14:04:21
O.K I checked the numbers they are all in neighborhood of July and Aug. Gee this is something I didn't know! (Along with a lot of other stuff!). I also checked the cub The serial number is 165313 J with dates 1-8-Y and 2-3-Y. What's the year on this?
rustyfarmall
08-21-2004 15:04:15
 Re: What year is this Farmall H? in reply to Brenda G. Hulsey, 08-21-2004 14:41:34
The Y code makes it a 1953.
Allan in NE
08-21-2004 13:57:29
Say Brenda,
Got to thinking. Are you absolutely sure it is an H? What is the complete serial # from front to back including the letters?
Allan
Brenda G. Hulsey
08-21-2004 14:45:36
 Re: What year is this Farmall H? in reply to Allan in NE, 08-21-2004 13:57:29
The numbers are FBH 37856.
Stan(PA)
08-21-2004 13:34:07
The serial number you provided shows that it is, indeed, a 1940. You can check the serial numbers in left column of this page. Click "Serial Numbers", then "Farmall", then "H", and it will show the STARTING serial number for each year.
Jim Broughton
08-21-2004 14:59:30
 Re: What year is this Farmall H? in reply to Stan(PA), 08-21-2004 13:34:07
Brenda;
Your Cub is a 1953 model. LOL Jim
Brenda G. Hulsey
08-21-2004 15:03:07
 Re: What year is this Farmall H? in reply to Jim Broughton, 08-21-2004 14:59:30
What do you know! We thought our "old" tractor was an 47 H and the "new" one was a 48 cub! Now in the matter of minutes we have a 40 H and 53 Cub. The wonder of the internet! Thanks guys, Brenda
