C information please
Bill Friedrich
11-10-1999 18:11:11
Looking for a little info on the IH "c".
Horsepower? and is there a thermostat in the "gooseneck" if the tractor doesn't have a water pump? Thanks Bill
Phil Auten
11-11-1999 05:30:16
 Re: c information please in reply to Bill Friedrich, 11-10-1999 18:11:11
Bill,
Guy Fay's IH Tractor Data Book lists the C as 2,780 lbs. without fuel or water. Field ready I would say 3,000 lbs. would be real close without any implements or fluid in the tires. If the tires are fluid filled, check M.E.Miller Tire's website for weights with fluid.
Phil
Phil Auten
11-11-1999 05:32:11
 Re: Re: c information please in reply to Phil Auten, 11-11-1999 05:30:16
Let's try this again. In case the link doesen't work, the address is www.millertire.com
Phil
Brian Schmidt
11-10-1999 21:03:29
I have seen several weights on a C and Super C. This link has it listed as about 5000 lbs.
As far as the thermostat, The C parts book shows no stat for tractors without a water pump. For tractors with a water pump the part number is 257 440 R91. This is a 165-195 degree range.
