starter conversion from non starter
brent fuller
09-08-2004 19:00:42
I'm thinking about converting my A(which didn't come with a starter) to an electric start system I already have a torque tube and a flywheel with ringgear,need to know what else I need to wire the starter. Oh,I'm gonna use a chevy alternator and such for the charging.
Stan(VA).
09-09-2004 04:51:35
 Re: starter conversion from non starter in reply to brent fuller, 09-08-2004 19:00:42
A dual pulley fan assy from one of the latter tractors with an elec system and the generator mount brackets might be usefull as a base to mod for the alternator. Make sure you have the starter engagement rod/brackets, two styles depending on what the torque tube came off of (early are push, later are pull); a battery box; and an instrument pannel (Amp/Volt meter, Ign switch, light switch).
Stan(VA).
