Farmall 806 head/rod torque, 301ci
806 Mike
09-13-2004 20:57:54
I looking for the torque specks for the head and rod bolts on a 806 /301ci engine. Thanks, Mike
El Toro
09-14-2004 08:01:44
 Re: Farmall 806 head/rod torque, 301ci in reply to 806 Mike , 09-13-2004 20:57:54
Hi Mike, The torque for the head bolts are 90 ft-lbs, mains are 80 ft-lbs, if the bolt shank is the same size as the threads the torque is 50 ft-lbs on the rods. If the bolt threads are thicker than the bolt shank, then the torque is 45-ft-lbs on the rods. Hal
