Farmall SM brakes
BG NY
09-14-2004 17:22:08
I am in the process of putting new brakes on my SM. Can any one tell me how to get the inner disc off of the transmission case. I need to put a new seal in, and I don`t see how you can do without taking that one casting off. My thanks for any help. Boyd
Aces
09-14-2004 18:57:31
 Re: Farmall SM brakes in reply to BG NY, 09-14-2004 17:22:08
BG if your are talking about a SM the inner disc looks like it is about 1/2" thick but it has a hub on it that goes into the pinion housing. So if you take two screw drivers there should be two places between the disc and the pinion housing to get the screws started and them pry a little at a time with the screw drivers and it should slide out it has an oring on the hud.
Good luck.
