Farmall A serial numbers
Alberta Farmall
09-16-2004 19:44:19
I am trying to figure out what all the number on the serial number plate mean. The plate is un-readable except for the numbers stamped into it. The plate has two numbers on it, the first is 287358 and below it is 1540. I think 1540 is the serial number but the other I'm not sure of. I was also under the impression that there should be a prefix number as well. Would the prefix be stamped in the plate or painted on with the rest of the information on the plate. Thanks.
chip man
09-17-2004 00:01:52
 Re: Farmall A serial numbers in reply to Alberta Farmall A, 09-16-2004 19:44:19
1540 is the maximum idle rpm.
Reddog
09-16-2004 20:36:27
The 287358 is the serial number. It should be 1950 Super "A" tractor.
