Converting 1466 W/Cab To Cabless
Adam Parsons
09-18-2004 17:49:09
What would it require to do this and what items would I need to purcahse to make it look like it came from the factory without a cab. Thanks
K.B.-826
09-18-2004 19:42:19
 Re: Converting 1466 W/Cab To Cabless in reply to Adam Parsons, 09-18-2004 17:49:09
What does it have on it? Factory cab or aftermarkret? Really dosen't take much if it is an aftermarket like a Hiniker, just lift off the cab itself and go. If it's a factory cab, you'll need a set of fenders, the left step and grab-handle at least, the right step and grab handle if you want, you'll need a pair of battery trays and covers, and I belive there were plastic trim panels on each side that ran above and to the rear of the batteries, those might be different.
Cliff Neubauer
09-19-2004 06:25:30
 Re: Converting 1466 W/Cab To Cabless in reply to K.B.-826, 09-18-2004 19:42:19
If it is a factory cab you will also have to find the correct platform as the cab tractor's used a different one than the open station tractors.
