oil pump removal W4 or H
Bob Quale
09-19-2004 15:04:57
Man am I having a bad day!! I droped the pan on my w4 or H type motor, and I can't get the oil pump out. Once the bolts are out it should just drop down I think? Am I missing something? What to do?
Thanks Bob
The Red
09-20-2004 03:32:35
 Re: oil pump removal W4 or H in reply to Bob Quale, 09-19-2004 15:04:57
Bob use a large pair of offset plyers and try twisting the pump. I had one on an H that was stubborn to get out. Once removed, wire brush the casting end on the pump and check for any burrs before re-installing.
Bob Quale
09-20-2004 14:00:54
 Re: oil pump removal W4 or H in reply to The Red, 09-20-2004 03:32:35
Red,
That was a good idea and it worked!!!! It was stubborn!!! My pump is bad and I broke it taking it apart. I have a new one on the way!!
Thanks Bob
Aces
09-19-2004 15:21:06
Bob The oil pump is the first place I would look. Some times the end plate get bad on them and leaks, make sure the relief valve is good. The cam bushings don,t go bad to ofton but then this tractor is 60 years old, who can say.
Aces
09-19-2004 15:16:33
Bob two cap screws in the pump after you remove the pan should do it.
Bob Quale
09-19-2004 15:40:26
 Re: oil pump removal W4 or H in reply to Aces, 09-19-2004 15:16:33
Thanks for the help!! I am going to try to tap the pump housing and see if it comes loose. I need to get it out in order to check the clearence.
Bob
