oil pump repair
Bob Quale
09-19-2004 16:02:55
Aces,
What am I looking for on the end cap or plate? Do I sand the pump cover or end plate so it is flat and install a new gasket? Then check end play so it is in spec?
Thanks Bob
Ed H.
09-19-2004 17:09:03
 Re: oil pump repair in reply to Bob Quale, 09-19-2004 16:02:55
i've done a few of them, you are welcome to call me.....email me back
Bob Quale
09-19-2004 18:15:06
 Re: oil pump repair in reply to Ed H., 09-19-2004 17:09:03
Ed H.
Your e-mail is locked out. I unlocked mine, shoot me a e-mail and I will hit you back.
Thanks Bob
Ed H.
09-19-2004 19:23:41
 Re: oil pump repair in reply to Bob Quale, 09-19-2004 18:15:06
ok, bob
MagMan
09-19-2004 16:25:05
I would take it to the neighbor hood machine shop and have it checked and or taken down. I would not try to sand it it has to be straight. Also As far as I know all engines get there pressure from cam bearing clearances I know the pump has to pump but then the pressure is built up through trhe cam bearings. JON
lee
09-20-2004 09:48:00
 Re: oil pump repair in reply to MagMan, 09-19-2004 16:25:05
never heard of that. If the bearings are loose the pump cannot build pressure but it's the pump that makes the pressure.
