LP Tractor
Andy in MN
09-22-2004 10:13:15
Does anyone here own any LP tractors. What kind of set-up do you need to fill the tanks. Are there any government regulations or certifications needed?
Thanks,
Andy
BIG JOHN
09-23-2004 18:16:21
 Re: LP Tractor in reply to Andy in MN, 09-22-2004 10:13:15
I have a MVLP that I only use for show and parades. A full tank of propane (80%) will last at least two years or more. When my propane driver sees the MV parked out by the propane tank he knows to fill it when he is filling the house tank.
One good thing is that the fuel never goes sour or gums up the carb.
GOOD LUCK WITH YOUR LP
KIP
09-22-2004 15:45:42
We had a 1000 gal bulk tank with a pump on the farm. While filling, we opened the tractor tank bleed vent valve until liquid appeared. The local propane company trucks used two hoses. The liquid hose and a vapor return hose, so there was no venting. We ran 4 tractors, windrower, cotton picker, and 3 pickups on LPG for years and never had any problems with that fuel. A Super C on LP is about as good as it gets.
Garry in OK
09-22-2004 14:07:44
Andy-
Dad's Super H has run on propane (add-on system) for 50 yrs MOL. A motor fuel type tank can be filled by pumping from a bulk truck/station or by the "gravity" method from a bulk tank-IF-the bulk tank is equipped with a wet line and the proper hose, fittings, etc. The tank being filled must have a dip tube that allows liquid to vent when the tank reaches ~80% liquid. Barbecue grill tanks are a different animal with their overfill protection device goodies.
Not sure about recertification on installed tanks, but the 100 lb'er on ole Dottie was just done this summer. Supposed to be done every 12 yrs if memory serves. It was built in 1950 and was recertifed about 1982, so we're keeping up pretty good (ahem).
Filling from a bulk tank should be safe as long as you keep fire or open flame away from the venting vapor. Use common sense, you're venting flammable vapor all the time it's filling. We limped in from the field many a time and started filling as soon as we got hooked up and never had any problem.
Regards
Wardner
09-22-2004 13:18:57
The problem with self fueling is that most small tanks do not have a liquid outlet. That means the portable tank has to be turned upside down. In very cold weather, the tank has to be elevated due to low vapor pressure.
Detachable forklift tanks have the liquid outlet. Fortunately I have six of these. My welding supplier made up a hose that will connect the forklift tank to my W400 propane tank.
Regulatiions are generally local. Check with your welding shop or propane distributer.
I live in an area that has natural gas and cold winter temperatures. Propane deliveries carry a surcharge around here when minimums are not reached.
If your tractor is not a working tractor, you might consider making an adaptor that would fit a soldering torch cannister to the liquid fill valve. There may be enough energy there to move several thousand feet. This would be a convenient but expensive solution. If you have leaks in your fuel system that you won't repair, it could be an economical solution.
GT
09-22-2004 11:14:08
Hi Andy, I have a 400LP and I just wait for the guy to fill the tank next door. He has all of the proper connections. Before you jump through hoops to fill it. Make sure all of valves seal good.
John A.
09-22-2004 20:10:38
 Re: LP Tractor in reply to GT, 09-22-2004 11:14:08
GT , Good to see you out and about here on the forum. Have you gotten up on your 400, Yet! Since the surgeries. How are things going? Well, I hope. Take care ,Hollar at me when you get a chance. Say Hi! To Mrs. GT for me.
Later,
John A.
Bob M
09-22-2004 10:41:58
A buddy of mine has a MM G on LPG. As it just parades and pulls, he only goes thru a tank or so of propane a year.
To fill it he simply calls the local propane dealer. They bring their bulk truck out and fill it right in the yard. Probably not the cheapest solution, but it's easy and safe.
Also he keeps a reserve tank consisting of a 20# (gas grill) bottle in a holder attached to the side of tractor. It's tee'd/valved so he can pull vapor off the 20 pounder in an emergency. Won't provide enough fuel to run the tractor long in cold weather, but will permit it to be moved to safe place should the big tank unexpectedly run out of gas.
