farmall A and b250
BUGGSY
09-22-2004 18:30:19
to start i would like to thank everyone for their information about my farmall A
second i have a b250 and winter is comming soon here in ontario and i would like to use it for snow removal will it start , and should i install a heater on it somewhere
thanks in advance
JB2
09-22-2004 19:22:41
 Re: farmall A and b250 in reply to BUGGSY, 09-22-2004 18:30:19
Hi, live in eastern Ont. and had a B414 Diesel that we used all winter. Had an 800W heater that was installed in the lower radiator hose as close to the block as possible. With a good battery and good glow plugs and 5W30 oil, it should start after being plugged in for about 1/2 hour on normal days and 1 hour on very cold days.
Good luck
JB
buggsy
09-22-2004 19:28:15
 Re: farmall A and b250 in reply to JB2, 09-22-2004 19:22:41
the hosesare pretty big do they make a heater with that big of inlet and outlet
also how do i tell if my glow plugs are working
thanks
JB2
09-23-2004 09:22:08
 Re: farmall A and b250 in reply to buggsy, 09-22-2004 19:28:15
Hi, I can't remember it has almost been 40 years since I last had the pleasure of driving neighbors B250 but I believe it had a glow plug indicator on the dash. You would turn the handle switch until the glow plug indicator glowed red and then start the tractor.
The glow plugs are wired in series like the old style xmas tree lights and if one burnt out none of them would work and the glow plug indicator would never glow. It would almost be impossible to start the B250 unless it was 90F outside.
JB2
buggsy
09-23-2004 09:29:46
 Re: farmall A and b250 in reply to JB2, 09-23-2004 09:22:08
hello
thanks for the info
there is no indicator so i bought a new one but it doesnt light up ??
JB2
09-22-2004 19:38:05
Hi, the heater that I am talking about fits inside the rad hose with the element pionting toward the block. You have to cut a hole in the rad hose for the electrical connection. The heater looks like one that goes in a frost plug in the block but is made to go in a hole in the rad hose. Canadain Tire use to sell them for about $10 30 years ago.
Good luck
JB
