I should clarify...
BillWV
09-29-2004 19:43:13
Two of the exhaust valves don't appear to be closing...with the head sitting on the bench. I was thinking more of carbon between the valve and seat rather than valve clearance.
I'm going to remove the valves and have the head hot-tanked; it is a mess looking in the exhaust ports.
Thanks,
Bill
gene
09-29-2004 22:31:29
 Re: I should clarify... in reply to BillWV, 09-29-2004 19:43:13
The valve stem is stuck in the valve guide. I don't think carbon buildup would prevent the valves from closing. Soak the stuck valve stems with penetrating oil for several days. Rap lightly on the stem head then soak again. Continue until the valve frees up.
Oil can get into the cylinder past the valve stem. But, I don't think the valve stem - guide clearence is all of the problem. You need a set of micrometers - measure the diameter of the stem and the bore of the valve guide. Couldn't find the clearence but somewhere around .001.
You have the head off. I think I would go ahead and do an in block overhaul. Pull the pistons, clean up the cylinders, and rering the pistons. Check the mains and rod bearings.
