distributor advance
bob quale
10-05-2004 17:41:05
In my distributor, there is a four sided thing that fits over the distributor shaft. It opens and closes the points and alowes movement of about ten deg to allow for the advance of the timing.
Should there be any side to side play in this?
Should it be lubricated when put back together?
Thanks Bob
rebuilder
10-06-2004 04:38:39
 Re: distributor advance in reply to bob quale, 10-05-2004 17:41:05
Bob Quale:
The item you are refering to is called the cam. It should not have any play, however any play you do see is more likely from the driveshaft/bushing it rides on. You should have minimum play. Excess play will afect the point gap setting. You need to check the cam for wear on the cam surface where the point lever rides. If it looks scoured or wore then get a GOOD used one at a salvage yard. As far as lube, I make sure the bore is clean of debris with a drill bit and cloth then use lubriplate(rebuilder's grease) and don't forget the felt which goes into the open end of the cam. this should be oiled regularly.
